Any one ever gotten the thermostat stock in there e3d hot end?
I’m thinking I’m going to have to heat it way up to get it out.
At what temp?
At room temp and 195c.
No solution for you
Can you push through the other side or is it the one that doesn’t use the through hole?
Why remove it ? If it is defective I suppose you could use a small drill …
Or crush it with an allen wrench
I had a resistor really tightly stuck in before, only easy solution without drilling was to crush it up
Its not a threw hole and I’m just going to leave it for now as its working. Just makes adjustments to the hot end or extruder harder.
yea the leads are very fragile. I usually buy them 4 or 5 at a time when I do because i break them everytime I mess with it it seems.
Yea I’m thinking I should pick up another one for when that day eventually arrives.
