Any one know of Borosilicate (or similar) glass suppliers in Aus (Adelaide would be better) ?
Finally happy with me printer’s settings and calibration so when to do a large multi-item print and use the whole print bed surface to have the print fail, looks like the Acrylic bed I have has a ‘sag’ in the middle, I hadn’t notices till now as the widest item I had printed was 60mm wide. * sigh *
Acrylic + Heat is going to cause problems. You want to use materials that aren’t going to deform around a heated bed.
You shouldn’t need any special glass as long as the surface is evenly heated. I use 3mm thick window pane glass and the only time I’ve shattered it is when I adhered ABS to it a little too strongly.
Try with regular glass before trying to source borosilicate.
Thanks @ThantiK , I realised what was happening as soon as I noticed the print bed had sagged, it’s probably only 0.2-0.3mm but that’s a Lot when your printing at 0.1-0.2mm
OK Good to hear about the window glass working, I think I’d still put some Kapton on it so if it does crack for any reason it’ll hold together.
Now to figure out how to mount it on, I know I could just hold it in place with clips but that doesn’t make me happy in the long term. Already ideas come to mind though.
I’m using mirrored tiles from bunnings, about 6mm thick, held in place with bulldog clips.
I tried picture frame glass, but it was too thin and it flexed to fit the PCB heater instead of the other way around.
@Ross_Hendrickson It’s not hard to cut glass. Buy a good cutter, use light oil, press hard, and only make a single stroke. Practice on some cheap offcuts first, but it is definitely a skill worth learning.
