Any suggestions or thoughts on the wire management would be great.
https://plus.google.com/+PanayiotisSavva/posts/guRHiycVcTG
Looks you are doing fine.
I like the way you mounted the bowden tube for minimum length. You should probably check it for interference with the build space at the extremes if you haven’t already. I’d also consider replacing the steel brackets holding the extruder motors with the aluminum ones that pololu sells, so that they can help sink heat to the frame.
