Any topic here about Timeout Issues.
Message: maximum number of timeouts has been reached.
I have this problem, more than I wanted, I already tried to reinstall but the problem continue.
The community needs to know a lot more about the configuration of your machine and what software you are using!
@donkjr Sorry, I use the K40 Whisperer software http://scorchworks.com
And I have this problem when the k40 is engraving is stop with the error message about timeouts!
Thnks for your time Don Kleinschnitz.
Hi, I read this same article yesterday, tried to move the cable but did not give great result…I Will try a new USB cable, thanks a lot for your time and everything you done.
LaserDRW doesn’t seem to be as sensitive to this problem so I am sure there is some programming that could help. However, I have not yet figured out what to do to help the problem.
@Scorch Hi, I change the USB cable and its works…no the error don’t happening
Thanks again for your time.
