Any update as to when FastLED will support the RGBW SK6812 chipset?
I searched on here and the last date anyone mentioned them was back in October. I’m going to pick up a meter from Adafruit to use in a lamp but would like to eventually use FastLED instead of Adafruit’s library.
Still working on it - (while there’s a trivial way to just support throwing an extra byte of data out - to actually support RGBW involves re-creating all the functionality we have that takes CRGB objects to take CRGBW objects (or - what I’m actually doing - is making it all generic and configurable - but it’s a large set of changes, and will touch nearly every piece of the library) - especially because, in the interest of optimizing memory usage, FastLED’s CRGB objects are only 3 bytes per pixel - and RGBW output requires 4 bytes per pixel. I don’t have an ETA yet for it though - there’ll be an announcement here when I do.
@Daniel_Garcia Thanks for the response. It’s good to know that it is being worked on.
I’m using these as well, purchased as RGBW Neopixels with warm white. The Adafruit Neopixel library initialization line says, “NEO_GRBW”.
Thanks Daniel!
I would love to hear from you about your update!
Thanks for developing this great library!
Is there any idea of an ETA for RGBW SK6812 support?
No, work and life haven’t given me much time to work on it over the past few months.
OK. I look forward to when you are able to. Thanks for the update.
Any updates on FastLED RGBW support?
Major development work on the library is on indefinite hold - please see the pinned post in this community.
