I have downloaded compiled and tested the controller (of course with a great help of Arthur).
Did someone else did the same ?
Yes I am here…
And I would like to use this nice grbl port on my mbed, which will be moving a laser beam…
Hi and welcome !
There is documentation ( very basic right now ) on the project’s main page: http://smoothieware.org/
If you have any kind of question/run into any trouble please don’t hesistate to ask.
What kind of laser ? Power ? What are you looking to burn/cut ?
I already ran into trouble.
I also tried to compile the code on the online compiler, but there it makes problems with the FATFilesystem. No solution found.
Then I wanted to compile the stuff on windows platform, and it didn’t like it, complaining about not findable include files etc.
Long story short, in the makefile there was the
SRC=./src/
line, which prevented correct compiling. After changing it to
SRC=./src
it now compiles. with hundreds of warnings of unused parameters, variable shadowing etc.
I want to use your grbl port to steer a galvo scanner which has analog voltage inputs. So I don’t need the stepper module, but some kind of similar module that outputs a given voltage at given time on an SPI based DAC.
Where should I start? Delete and write from scratch? Actually I don’t really understand the functioning of the Stepper, where the ticks come from, etc…
That’s to be expected, smoothie is quite young, and while it’s attracting interrest fast, I’m still mostly alone to code it and use it right now.
I did not try to compile using the online compiler since the very early stages.
That’s quite normal for code in this stage
The important thing right now is that it works.
This may be of help to you : http://smoothieware.org/howitworks
Can you tell more about what a galvo scanner is ? That would help ![]()
But indeed, it seems what you want is a modified Stepper module.
The way to do this is :
If you need any help, don’t hesitate : here or at wolf.arthur@gmail.com
Cheers !
Oh ok, yes indeed, to control it via spi dac you’ll have to code a new Stepper module.
Should be quite similar to the normal Stepper module.
You’ll also need to make a new ArmSolution module, to translate xy positions into rotational positions, the structure for that is already inside, you just need to customomize.
Cheers !
Where is the .cpp code of the ring buffer? you committed the .o file
All of the code for that one is in the .h, there are a few purely utilitarian files that are this way.
