Anybody know where I can get Aluminum Extrusion (like 80/20 stuff) inexpensively? The cheapest I’ve found is at Reid Supply, but the shipping on pieces longer than 96" is HORRIBLE because it has to be shipped via commercial freight…
EDIT: This is in the States. I live in Portland, Oregon. (sorry for my provincial assumptions! lol)
@Edward_Ford - thanks! But unfortunately, the inventables extrusion is too small a cross-section for my application. My CNC is quite large and needs 1.5"x4.5" cross-section extrusion…with a 108" length…
Regarding the OP: You might want to check misumi then. In their 5 series of extrusions you can get up to 40mm x 80mm, which would get you roughly 1.5" x 3+". Or, if you went up to their 6 series, you could get a 50mm x 100mm at the length you require (2743.2mm).
Their part numbers are wonky, but I think you are looking for HFS6-50100-2743
Their standard cuts are promised to be +/- 1mm, so your .2mm might be an issue unless you request the “high precision” cut… .which is pricey.
Grainger has long pieces. It you have a local branch you could save the freight, so even with the higher price it might be cheaper. Your company might have a Grainger account already and they might let you use it if you pay cash at pickup, or you might qualify for one of Grainger’s deals. I’m a couple hundred miles from the nearest office, but they’ll free ship to me because I’m a Farm Bureau member - even one piece that comes truck freight. Won’t hurt to check them out.
