Anybody using a DeltaMaker?
Anybody using a DeltaMaker? I am trying to find settings for Simplify 3D and / or Cura.
I work for them; We don’t have settings for Simplify3D.
The relevant specs of the machine, however, are nozzle size (0.35mm), and filament diameter (1.75) - Diameter of build plate is 240mm, height 270mm - you’ll need to set the machine as a Delta with 0,0 being the center. In expert settings you’ll want to set a 1mm Z-hop, but otherwise there isn’t a bunch of settings that need to be changed.
Give me a little and I’ll see if I can build a profile for you.
https://drive.google.com/file/d/0ByxvvRr2A-puNkpLODVUWTFiTHc/edit?usp=sharing - There’s an INI you can import.
Here’s some screenshots of all the settings, just in case that import doesn’t catch everything: https://drive.google.com/file/d/0ByxvvRr2A-puMVZBMExNRVI4b00/edit?usp=sharing
I made all of this in a hurry, apologies if I missed something.
Also, Internally we’re using KISSlicer for most of our prints. I can provide those too (if I haven’t fallen asleep by the time you’ve replied)
Additionally, I’m doing my best to design a new hot end mount for the E3Dv6 with a nozzle-based probe (off of DeltaMaker hours) - I have a weird problem with actually participating in the Google Groups group that we have set up…and keeping track of emails sent to support. Trying to get better at it. :[
Thanks! I would love all the slicer settings you have. I need to land on something better than Slic3er :slight_smile:
