Anybody using repetier firmware on a delta?
Id really like to make a switch from marlin, but im seeing this weird artifacts with repetier. All of the straight lines are wobbly. Its hard to explain, looks like a bad case of early reprap’s using T5 printed belts and wobbly carriages. It is definitely not so called delta effect. This is just too regular and visible only on straight lines.
With marlin everything is straight as it should be.
Any ideas where to start fixing if possible?
Delta segments per, have a look in configuration.h or now with 091 in eeprom hi can adjust it. Default is like 170 for print moves, increasing it gives finer detail but lowers max speed etc
If marlin works well, why are you switching to repetier?
Thanks @J_O11 I’ve been trying occasionally from time since 0.81 and hoping this was some kind of bug that they get might fix, never tried increasing the number, but have tried lowering it with no effect whatsoever. Its 180 at default in 0.91.5. Any recommendation how much to increase?
@Shachar_Weis many reasons, more linear speed over build area, easier setup for multiple extruders, easier setup for eprom, ect.
