Anyone can help me with smoothie. I am totally smoothieware noobie, today start change my ramps with re-arm board to smoothie. Now many things works ok.
Example:
Hotend starts heat ok and right sensor.
Hotbed start heat ok and right sensor.
x y and z movement (with octoprint goes right ways and right axles)
graphic display works ok.
Problems.
When i send M80 command to start my ATX power, console give feedback: “Recv: Kill button pressed - reset or M999 to continue”
And if i write again M80 power start up normally and work ok. M81 command works ok. -
Maybe bigger problem is zprobe (z endstop?)
Can i use inductive sensor (plugged min enstop pin) to use that z endstop and same time to zprobe because to offset and autobed leveling?
Now i not get any signal changes to zprobe display (M119) when i trigger inductive sensor. Inductive sensor give 3.3volts mainboard and 0.2volts when not triggered.
M119 give everytime same Probe: 0 back to me. Is that something to smoothiewiki tells probe not can be used z endstop? Is that true or can i do some settings to use same inductive sensor probe z and endstop same time?
M119 command give this kind feedback:
Recv: X_min:1 Y_min:1 Z_min:0 pins- (X)P1.24:1 (Y)P1.26:1 Probe: 0
So many thanks if someone can help me with this.
