Anyone else had a look at the 'Secret Marlin' repository on github?  Lots of
Anyone else had a look at the ‘Secret Marlin’ repository on github? Lots of Ultimaker 2 settings to appropriate for those of us with bots that use the same mechanics.
https://github.com/Ultimaker/SecretMarlin/tree/master/Marlin
Extruder runout prevention has been in the mainline marlin for some time, it’s just disabled by default. Those other things sound cool, though.
Actually, checking my local copy of the mainline Marlin, those other two features are in there too.
Huh, I’d not noticed any of them previously. I assume you’ve had no experience with their efficacy then?
We use extruder runnout prevention on the Deezmaker machines. It works well, though the configuration options aren’t very well described. The other two options are enabled by default, and I haven’t messed with them, but I assume they’re doing good things.
All of these have been in Marlin for quite some time now.
@ThantiK Apparently so, my bad - I’m going to prune the post accordingly. Ultimaker2 settings still useful (for me at least).
Still; check out the commit log to see what’s actually being done in that branch. Sometimes I like to cherrypick changes from other branches to test with. :slight_smile:
Hey, i see that theres a custom menu, does anyone knows if it will work with any lcd or just with the one on the ultimaker?.
Also, where i should look to add stuff to the menu?, cant find the code.
