Anyone experienced this error on K40 Whisperer? "The laser cutter stopped responding after sending.
Hi there,
I know this is an old post but did you found a solution? I figured i could continu the job by removing and replacing the cable and the machine start again but still annoying…
This was imported from the Google+ group and @Vilius_Kraujutis_vil has not logged into this site, so has no notification of your question.
If you have tried everything you can on the physical side and want to try to rule out software, you can always try using MeerK@t which is an independent and different implementation of similar functionality. I don’t even own a K40 so I just think it’s amazing that two different people have independently built software workarounds for super-limited hardware. :smiling_face:
