Anyone has a pool skimmer cover design made ?
Are they standard? If you send me some measurements (top diameter, bottom diameter, lip thickness/height, top thickness) I can design one for you. Probably will need a large print area, though.
Designing it is not a problem. Just wanted to see if someone had one already made.
As for size standard, I’m not sure either.
For print area I was thinking of 2 half circle with an interlock that would be used to glue the 2 half together.
Yes, I was wondering about something like that. Or even quarters, depending on your printer.
