Anyone has a working config.txt for a Corexy setup specifically for D-Bot but for now even any Corexy for MKS SBase 1.3? Changed out my ramps but cannot get this board to work. My motors make a hissing sound and get hot even though i set the current for all motors to 0.4. Also where do you connect part cooling fan and hotend fan to work when required and not all the time stay on? Thanks for any and all input.
Smoothie ware has a scaling factor that the digital current control uses to handle those drivers. If you don’t have the correct config.txt for your board, it’s possible it isn’t scaling the current correctly for you. Search around for an MKS SBase specific config file first then modify it to your liking. There are not many people that like to help with that board unfortunately cause MKS is not community supportive.
Thanks. After scouring I managed to find config.txt from instructables. The config file is hidden in the comments. When i get home tonight i will give it a try if not i will need to sit and do it the long way which i was trying to avoid.
So that didnt work out as planned. The x endstop is resetting the board. Tomorrow will get a new endstop and continue with the setup.
@Griffin_Paquette I managed to get rid of the heating by reducing current to 0.3(75%) from 0.4(100%). The hissing sound is unfortunately from the DRV8825 drivers itself. Everyday I get a little closer to getting it to work.
