The current simple box shaped one is falling off constantly. Also isn’t directional enough and keeps lowering the hotend to the emergency cutoff limit.
Even without emergency cutoff. And temp set to 230. The hotend can’t keep up. And I’m using the upgrade 24v cartridge too it kept falling under 190c
The ducts on my carriage still don’t perform as well as I’d like. Making a better version is on my list of things to do… I need a solution that works as well as the duct I made for the Tria. That works better than I would have hoped.
@Jim_Stone Do you mean you had to beat your rods into the bearings on the corner brackets? The first rods I bought weren’t spec’d for the bearings and I had a similar issue but I ditched them for Misumi and the fit was flawless. Worth every penny
@Jim_Stone Its unfortunate that I didn’t have my new XY belt tensioners designed when I sent you those parts… That would have allowed you to change the carriage without taking out the guide rods on the side
@Greg_Nutt if i was gonna do that. i would spend the money that went into that…on the new style e3d block upgrade with the silicone sock theyre making.
that would literally solve my problem and i know it.
but me being me and the doofus i am. i have to not spend money first
@Jim_Stone Its just a thin barrier and apparently it does degrade over time. I haven’t seen any life-changing revelations from anyone using the silicone sock, but maybe I haven’t been following it close enough.
@Jim_Stone My modified carriage and fan ducts use 40x20mm fans. This would easily explain your problems if you are using the 50x50x15mm fans specified in the BOM. Are you using the 50mm fans? If so, let me know and I will do my best to design you a fan duct that works for that situation.
