Anyone know of addressable uv LEDs? I’d like to embed them in glow in the dark 3d printed shapes so I’d prefer a form factor that’s easy to solder (strips would be fine).
If you were to use discrete devices it would be quite easy … you want it to be compatible with FastLED … that would be more involved but I might be able to design something for you …
Are there discrete programmable ones? I want a bus, not a mess of wires.
Are you sure about those? The one line description sounds right but there are three difference strips in the pictures (none of which are UV) and the description calls them cool white with a color temp of 6000k.
nope … there’s a link to ask seller a question … give it a try
Here is a link to addressable UV LED strips using the LPD8806 driver chip: http://www.greeled.net/uv-led-strip-lpd8806.html
GreeLED is a reputable company that I have purchased from before. As with most factory suppliers, they do require some back and forth communication, and they might take a little while to ship. If I remember correctly, I might have had to use an international wire transfer, which can be a pain and slightly expensive. That said, they will likely customize to anything you want as far as PCB color, pixel density, IP rating and so on. Who knows, they might have updated there payment methods to include credit card. Please let me know if you end up using them. Cheers
Awesome! Thanks!
