Anyone know the pin callouts for the designated servo pins on the Azteeg X5 GT?
Not on their diagram that I can see, and I’m not seeing schematics for the GT anywhere…
That’s cool what you do… hope you be my friend
@Mikayla_Griffin Stop spamming posts and remove your comments
@Taylor_Landry did you figure it out? I’m replacing mine this weekend and have a BLtouch working off my X5 GT. I can look to see if the config file has what you need
Haven’t yet, but I can make it work on one of the free PWM pins, but I specifically want to use the designated servo pins (next to the VFD pins)
Not sure if it helps, but this is from my config file: switch.servo.output_pin 1.23 # must be a PWM capable pin
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29 # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 300 # move feedrate mm/sec
zprobe.probe_height 10 # how much above bed to start probe
switch.servo.enable true #
switch.servo.input_on_command M280 S3.5 # M280 S7.5 would be midway
switch.servo.input_off_command M280 S12.5 # same as M280 S0 0% duty cycle, effectively off
switch.servo.output_type hwpwm # H/W pwm output settable with S parameter in the input_on_comand
#switch.servo.pwm_period_ms 20 # set period to 20ms (50Hz) default is 50Hz
Yeah, I have that from the sample config, but unless my servo is bad, it’s not the right pin
And, sure enough, servo was bad. Thanks. Sometimes I forget Occam’s razor.
