Anyone tried these yet? Strip looks like it can be twisted in interesting ways:
http://www.gree-leds.com/productshow.asp?ArticleID=2T0X3QY99Z
I wonder if they can resist to repeated lateral movement… Maybe a solution to my Firewalkers breaking every time I use them
I used some on a wearable project recently and they worked great. I bought mine off of Aliexpress though and the strip is the same width as the LED chip which was an added bonus.
@Brian_Lewis Very nice! Could you share the link?
@Franck_Marcotte https://www.aliexpress.com/item/SK6812-RGB-bendable-addressable-LED-pixel-strip-48leds-with-48pixels-m-non-waterproof-WHITE-PCB-DC5V/32613499798.html?spm=2114.13010608.0.0.DyiK2R
We’ve got the thin ones in our store as well: http://shop.blinkinlabs.com/collections/leds/products/serpentine-led-strip
They seem pretty resilient, however I’d recommend reinforcing them with a stronger material.
Thanks for the links! @Matt_Mets any chance those will be available in 60/m eventually or is there some sort of physical limitation to this technique?
Hmm, it seems like it would be physically possible to make a 60/m version, but it starts to cut into the space left for a bend radius and for cutting between the LEDs. If I see any I’ll post here.
