anyone tried gcodeprintr with #Printrbot Simple 2014 yet? Just ordered one after canceling my #Makibox order.
I think @John_Davis uses GCodePrintr on a Printrbot (not sure which printrbot model)
If it doesn’t work out-of-the-box, Mathias is magic - he will use his mind to bend and shape the code to work for your printer
Not that this is ANY help at all, but I would assume if your printer uses G-code (almost all do) then most functions should work. Everything works on my RepRapPro except ‘reset’ - but this doesn’t work using repetier or pronterface either - it is an issue with the printer and GCodePrintr does everything that I can do with other ‘Host’ software…
I see printrbot simple uses repetier actually, so it’s definitely G-code and I would say anything that works through repetier should work (or be able to work if you tell Mathias you have an issue) with GCodePrintr
