Isn’t 19w down to 15w only a 78.95%? Thus a loss of 21.05%?
Also, 24w down to 18.5w is 77.08%, thus a loss of 22.92%.
Unless my math is wrong or I am misunderstanding your measurements.
edit: Oh, nevermind me… I just realised after 2 mirrors… so approximately 10-11% each. Although I’d imagine the loss will be exponential the more mirrors it passes through?
Yes it’s probably not linear, I’m just a bit surprised the loss is that high to be honest. Wondered if that was acceptable or whether my homemade hard drive mirrors aren’t as good as the real thing!
You may be interested in this guys youtube channel he has proven that home made polished copper mirrors are the beat way forward with the least amount of power loss. I will also add that his continued testing I have found invaluable covering all things Chinese laser related so he is worth bookmarking. https://www.youtube.com/watch?v=kJe16YQlIM0
Especially @Paul_Hayler link(s). Having watched two of RDWorks videos now they are definitely worth watching.
Russ (RDWorks) demonstrated aluminium, which hdd platters contain (and most beds are made from), aren’t the most effective choice of mediums though still reflect nearly 80%!
Also @Ari_Diacou graph shows my loss is much higher than it should be.
So it seems the HDD mirrors are robbing me of power. Given I have hole saws now, I shall be sourcing some copper to make a few mirrors.
I have a few projects on the go, but hope to update soon.
I’ve looked at a few local suppliers, around 1mm thick seems about standard but I’m concerned it’s not thick/hard enough and it wont provide a perfectly flat surface.
Russ (rdworks) shows in one of his videos how he hones them flat and then gets a mirror polish on them. I do a slight variation on this as I didn’t have a chunk of steel but it gets the job done. its also worth noting once you have them polished up if they are not quite flat you would notice straight away by the reflection showing distortion.
Ah, to be honest I’d only watched videos 1 & 2, must have missed him talking about making them at the end of two.
Another thing to consider possibly, if copper oxidises would it be better to make them out of something else? Might not be as efficient but you wouldn’t have to pull them out and polish them every couple of months and totally realign the machine.
Finaly got around to testing power output,straight out of tube at 18ma was 38 watts [meter is calabrated to 54 seconds-etrched on back] 54 seconds laser on and 2mintutes rest,with power probe insulated from all metal[which would act like a heatsink and result in a lower reading] as well as probe at 90 to beam.After the first mirror[which is the silver type and new] power output was 38 watts .After 2nd mirror[used but freshly cleaned] 37 watts .After 3rd mirror power 36 watts[again used mirror ,freshly cleaned.all reading taken in an air conditioned room at 22 degrese.water temp at start of tests was 14 degreas,and finish 16 degrease .
These readings are what i would have expected and tube was a replacment with approx 300hours on it.
That is an amazing result @Phillip_Conroy I’ll be happy if I can get it down to a loss of 5-10% across the lot but it seems a bit of a dream at the moment lol.
After watching a lot more of Russ’s videos I wondered whether you could even grind down the standard mo mirrors and polish them back up (all of mine were scratched when they arrived). I assume they have a coating on them though.
