Are there clear instructions for removing the frame and squaring. preferably with pictures. Thanks
If you find one please let me know I am looking for one as well my laser is in a few pieces now as I took it apart to cut down the exhaust. Now I got to get it squared and aligned should be painstakingly fun
can you send instructions for removing the frame please
It’s easy
- Use an Allen wrench to remove the five screws from the bed silver bed so that it can be removed.
- Use an Allen wrench to remove the black plate at the bottom this is covering access to the two booths that are holding the frame down
- Use and Allen and lift up the machine to unscrew the five post that where holding up the z bed. Access to these are on the bottom of the machine
(I replaced my bed with a grate I cut down from Home Depot. And used these post and some washers to support it.)
Use a pair of pliers to remove the four bolts holding the X and y axis down
Disconnect from the board (the ribbon cable just pulls out)
Gently lift it out and be sure not to knock the mirrors
