Argh. Another C++ syntax quickie. How do I declare an array of Palette objects and iterate through them?
CRGBPalette16 *palettes[] = {
&RainbowColors_p,
&RainbowStripeColors_p
… gives me a “too many initialisers…” error.
&RainbowColors_p,
I think you have to specify the array size. Put a 2 in those square brackets.
Doesn’t help
“cannot convert ‘const prog_uint32_t ()[16] {aka const long unsigned int ()[16]}’ to ‘CRGBPalette16*’ in initialisation”
(those asterisks are not doubled in the original output, I had to double them up to stop G+'s markdown interpreter being clever.)
Try:-
CRGBPalette16 palettes[] = {
CRGBPalette16(RainbowColors_p),
CRGBPalette16(RainbowStripeColors_p)
I think that will work but as I have only just downloaded the updated 2.1 with palettes, & blending I don’t have much experience yet
I think the reason you were having problems is that the predefined palettes are defined in PROGMEM and need to be copied to regular memory to be used.
Thanks @Aaron_Liddiment , that worked great. My plasma pattern can now cycle through palettes on a button-press.
