As important as it is to ensure all your settings are correct before printing, I only just thought about adjusting the flow rate mid print to fine tune the quality without reslicing. I’m sure many of you already do this but if you don’t already, I highly suggest it if you’ve just started a print and it looks ever so slightly over extruded.
Those without an LCD panel cal also use M221 S(multiplier in percent), so for example M221S98 to compensate for slight overextrusion.
I don’t have an LCD control panel, so I just adjust it in Repetier’s manual control tab
