at what point do you stop adding to your project,
at what point do you stop adding to your project, I was bored this afternoon and did this, just as a side, anyone wanting to add osc control to their LED project without needing a library then hit me up :wink:
https://www.youtube.com/watch?v=A-B8HkuYUJQ&feature=youtu.be
I’m hitting you up! This is an official hit up! Great work, I’ve been following your posts regarding your work on the Artnet Box, the mic stand was a great idea too.
Will stick some of the code up on pastebin in the morning Jon, also found a dead cheap way to add wireless to arduino uno projects, a cheap wiznet shield and a tp-link wr702n, it can run in client mode or access point mode so its dead flexible, plus if you take it out of the case the board is about half the size of an uno board…and it runs on 5v :slight_smile:
Awesome!
I’ve done similar with other travel wifi/ethernet boxes… and every time, it makes me nuts: If the ethernet shield is $9, and the wifi adapter is $20, then WHERE THE HECK IS OUR $29 WIFI SHIELD??
I suppose the Adafruit (et al) $40 wifi shields are pretty close. But still.
