Hey all,
I can see the finish line for my BLTouch install but have hit another snag. My leveling strategy completes and probes as it should but I see no movement in my Z axis during the print even though their is a visible area of the bed that is too low. Im not sure if im missing something simple in my startup gcode sequence or if it has something todo with gamma_min and gamma_max. Should there be a part of the startup code that saves and loads the probed points?
Here is my startup gcode
G28 Z; home Z in case its somewhere unknown and I ask it togo down 10 G1 Z10;Lower bed so probe has room to extend M280S3; drop probe down to probing position G32; run bed leveling strategy
G1X512.5Y80F6000; No bed lowering but move to probe point 1 to set the bed height
G30 Z0.6; Desired Z-offset
M280S7; raise bed probe up
And here is my config file
# Robot module configurations : general handling of movement G-codes and slicing into moves default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation #mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 118.52 #changed from 80 Steps per mm for alpha stepper
beta_steps_per_mm 118.52 #changed from 90 Steps per mm for beta stepper
gamma_steps_per_mm 4031.5 #changed from 1600 Steps per mm for gamma stepperPlanner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 700 # Acceleration in mm/second/second.
#z_acceleration 500 # Acceleration for Z only moves in mm/s^2, 0 disables it, disabled by default. DO NOT SET ON A DELTA
junction_deviation 0.01 # Similar to the old “max_jerk”, in millimeters, see :Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for steppingStepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11 # Pin for alpha stepper direction
alpha_en_pin 0.10 # Pin for alpha enable pin
alpha_current 1.34 # X stepper motor current
x_axis_max_speed 9000 # mm/min
alpha_max_rate 9000.0 # mm/min actuator max speedbeta_step_pin 2.2 # changed from 2.1 Pin for beta stepper step signal
beta_dir_pin 0.20 # changed from 0.11 Pin for beta stepper direction
beta_en_pin 0.19 # changed from 0.1 Pin for beta enable
beta_current 2.0 # changed from 1.5 Y stepper motor current
beta_max_rate 9000.0 # changed from 30000mm/mingamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 2.0 # Z stepper motor current
z_axis_max_speed 300 # mm/min
gamma_max_rate 300.0 # mm/min actuator max speedSerial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)#msd_disable false # disable the MSD (USB SDCARD) when set to true
#leds_disable true # disable using leds after config loaded
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdogExtruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
#for volcano
extruder.hotend.steps_per_mm 807.92 # 810.75 redid March 18 @90 and 250 temp and got 807.92 Steps per mm for extruder stepper extruder grip was at right end of second marking
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 100 # mm/sextruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5 # Pin for extruder dir signal
extruder.hotend.en_pin 0.4 # Pin for extruder enable signaldelta_current 1.34 # Extruder stepper motor current
Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microsecondsFirst hotend configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend.heater_pin 2.5 # changed from 2.7 Pin that controls the heater, set to nc if a readonly thermistor is being defined
temperature_control.hotend.designator T #
temperature_control.hotend.max_temp 385 # changed from being commected out and 285 is max tem for nozzle change anyways Set maximum temperature - Will prevent heating above 300 by default
temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below if settemperature_control.hotend.sensor pt100_e3d
temperature_control.hotend.e3d_amplifier_pin 1.30 # must be a free ADC pin, not a temperature input#temperature_control.hotend.thermistor_pin 0.24 # changed from 0.23 Pin for the thermistor to read
#temperature_control.hotend.thermistor Semitec # changed from EPCOS100k see
#temperature_control.hotend.beta 4066 # or set the beta valuesafety control is enabled by default and can be overidden here, the values show the defaults
temperature_control.hotend.runaway_heating_timeout 600 #CRITICAL TO NEVER COMMENT OUT if the printer loses connection this is how it stays safe if it doesnt get an okay im alive signal within this time it shuts down and restart killing any running esxtruders! I timed and from coldstart took 3 minutes to get to 230 and 9 minutes to get to 285 so set to 600 seconds MAX is default max is 2040 seconds, how long it can take to heat up
temperature_control.hotend.runaway_cooling_timeout 0 # max is 2040 seconds, how long it can take to cool down if temp is set lower
temperature_control.hotend.runaway_range 40 # Max setting is 63°C (was off by default)
temperature_control.hotend.i_max 500#fOR VOLCANO
temperature_control.hotend.p_factor 85 #OFFICAL PID CALCULATED NO FANS 45.7 3.837 136 JULY 20 2017 PREVIOUS 85 2.427 80 previous 41.7 2.427 and 175 ran again for new ones at full fan at 250
temperature_control.hotend.i_factor 2.427 # 41.7 2.149 203 run at 250 March 18 full fans against bed
temperature_control.hotend.d_factor 80 #temperature_control.bed.enable false #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.thermistor EPCOS100K # see
#temperature_control.bed.beta 4066 # or set the beta valuetemperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 1.25 #switch.misc.enable false #
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 0.26 #automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervalsfilament out detector
#filament_detector.enable false #
#filament_detector.encoder_pin 0.26 # must be interrupt enabled pin (0.26, 0.27, 0.28)
#filament_detector.seconds_per_check 2 # may need to be longer
#filament_detector.pulses_per_mm 1 .0 # will need to be tuned
#filament_detector.bulge_pin 0.27 # optional bulge detector switch and/or manual suspendSwitch module for spindle control
#switch.spindle.enable false #
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
#corexy_homing false # set to true if homing on a hbot or corexy
alpha_min_endstop 1.24^! # add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.24^ #
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 600 # this gets loaded after homing when home_to_max is set
#beta_min_endstop 1.26^ #
beta_max_endstop 1.26^! #
beta_homing_direction home_to_max #
beta_min 0 #
beta_max 600 #
gamma_min_endstop 1.28^! #was 1.28^!
#gamma_max_endstop 1.28^ #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 600 #alpha_max_travel 610 # max travel in mm for alpha/X axis when homing
beta_max_travel 625 # max travel in mm for beta/Y axis when homing
gamma_max_travel 600 # max travel in mm for gamma/Z axis when homingoptional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches
#move_to_origin_after_home false # move XY to 0,0 after homing#probe endstop
probe_pin 1.29 # optional pin for probealpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 4 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 2 # "alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 1 # "#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29 # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 70 # move feedrate
zprobe.probe_height 10 # how much above bed to start probeswitch.servo.enable true
switch.servo.input_on_command M280
switch.servo.input_off_command M281
switch.servo.output_pin 2.4
switch.servo.output_type hwpwm
switch.servo.pwm_period_ms 20associated with zprobe the leveling strategy to use
leveling-strategy.three-point-leveling.enable true # Set to true to enable the leveling strategy that probes three points to define
# a plane and then keeps the Z parallel to that plane. This is useful if
# your Z plate/bed is not perfectly aligned with your XY gantry
leveling-strategy.three-point-leveling.point1 512.5,80 # The first probe point (X, Y)
leveling-strategy.three-point-leveling.point2 512.5,555 # The second probe point (X, Y)
leveling-strategy.three-point-leveling.point3 62.5,555 # The third probe point (X, Y)
leveling-strategy.three-point-leveling.home_first true # Home the X and Y axes before probing
leveling-strategy.three-point-leveling.tolerance 0.03 # The probe tolerance in millimetres, anything less that this will be
# ignored, default is 0.03mm
leveling-strategy.three-point-leveling.probe_offsets -1.5,-46,0 # The probe offset from nozzle, must be X,Y,Z (Z should always be 0),
# default is no offset. This is used if your nozzle is not exactly
# at the same position as where your tool would be.
leveling-strategy.three-point-leveling.save_plane false # Set to true to allow the bed plane to be saved with M500, default is falsekill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
#kill_button_enable true # set to true to enable a kill button
#kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)Network settings
network.enable true # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
#network.ip_address auto # use dhcp to get ip addressuncomment the 3 below to manually setup ip address
network.ip_address 192.168.0.99 # the IP address
network.ip_mask 255.255.255.0 # the ip mask
network.ip_gateway 192.168.0.1 # the gateway address
#network.mac_override xx.xx.xx.xx.xx.xx # override the mac address, only do this if you have a conflictAzteeg specific settings do not change
currentcontrol_module_enable true #
digipot_max_current 2.3 # max current
digipot_factor 113.5 # factor for converting current to digipot value
