I just built a Hypercube Evolution, with an azteeg x5 GT, and I’ve got it working and printing, but either my 420x420 cast aluminum tooling plate isn’t flat, or my carbon fiber rods aren’t straight, so I’m trying to compensate with auto leveling using a BLTouch like I have on my custom prusa i3 with marlin.
The problem is that the leveling doesn’t actually take effect. The z rods never turn, and the edges are printed higher off the plate.
I’ve run through a 7x7 auto level sequence, then saved the results to the cartesian.grid file on the SD card. I have it set to load from save in the config file, and I can run M375 after a reboot, and it loads, but never compensates. It doesn’t compensate even if I run an auto level sequence from the gcode of my print each time. Could it have anything to do with being a corexy?
Here is what I get on console
<ran autolevel>> M374
grid saved to /sd/cartesian.grid
ok
> M500
Settings Stored to /sd/config-override
ok<rebooted>
>M375
grid loaded, grid: (397.000000, 397.000000), size: 7 x 7
ok
My config file
# Robot module configurations : general handling of movement G-codes and slicing into moves arm_solution corexy default_feed_rate 1000 # Default rate ( mm/minute ) for G1/G2/G3 moves default_seek_rate 1000 # Default rate ( mm/minute ) for G0 moves mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation #mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 320 # Steps per mm for alpha stepper
beta_steps_per_mm 320 # Steps per mm for beta stepper
gamma_steps_per_mm 3200 # Steps per mm for gamma stepperPlanner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 500 # Acceleration in mm/second/second.
z_acceleration 500 # Acceleration for Z only moves in mm/s^2, 0 disables it, disabled by default. DO NOT SET ON A DELTA
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.05 # Similar to the old “max_jerk”, in millimeters, see :
# . Lower values mean being more careful, higher values means being faster and have more jerkStepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for steppingStepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11! # Pin for alpha stepper direction
alpha_en_pin nc # Pin for alpha enable pin 0.10
alpha_current 0.5 # X stepper motor current
x_axis_max_speed 3000 # mm/mi
alpha_max_rate 18700.0 # mm/min actuator max speedbeta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20! # Pin for beta stepper direction
beta_en_pin nc # Pin for beta enable
beta_current 0.5 # Y stepper motor current
y_axis_max_speed 3000 # mm/min
beta_max_rate 18700.0 # mm/min actuator max speedgamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction
gamma_en_pin nc # Pin for gamma enable
gamma_current 1.0 # Z stepper motor current
z_axis_max_speed 300 # mm/min
gamma_max_rate 300.0 # mm/min actuator max speedbigfoot settings
motor_driver_control.alpha.enable true # alpha (X) is a TMC26X
motor_driver_control.alpha.designator X # A to set the settings
motor_driver_control.alpha.chip TMC2660 # chip name
motor_driver_control.alpha.current 1000 # current in milliamps
motor_driver_control.alpha.max_current 3000 # max current in milliamps
motor_driver_control.alpha.microsteps 32 # microsteps 256 max
motor_driver_control.alpha.alarm false # set to true means the error bits are checked
motor_driver_control.alpha.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.alpha.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.alpha.spi_cs_pin 0.10 # SPI CS pin
#motor_driver_control.alpha.spi_frequency 100000 # SPI frequency
motor_driver_control.alpha.sense_resistor 100 # set the sense resistor used.motor_driver_control.beta.enable true # beta (Y) is a TMC26X
motor_driver_control.beta.designator Y # B to set the settings
motor_driver_control.beta.chip TMC2660 # chip name
motor_driver_control.beta.current 1000 # current in milliamps
motor_driver_control.beta.max_current 3000 # max current in milliamps
motor_driver_control.beta.microsteps 32 # microsteps 256 max
motor_driver_control.beta.alarm false # set to true means the error bits are checked
motor_driver_control.beta.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.beta.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.beta.spi_cs_pin 0.19 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.beta.spi_frequency 100000 # SPI frequency
motor_driver_control.beta.sense_resistor 100 # set the sense resistor usedmotor_driver_control.gamma.enable true # gamma (Z) is a TMC26X
motor_driver_control.gamma.designator Z # G to set the settings
motor_driver_control.gamma.chip TMC2660 # chip name
motor_driver_control.gamma.current 1500 # current in milliamps
motor_driver_control.gamma.max_current 3000 # max current in milliamps
motor_driver_control.gamma.microsteps 32 # microsteps 256 max
motor_driver_control.gamma.alarm false # set to true means the error bits are checked
motor_driver_control.gamma.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.gamma.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.gamma.spi_cs_pin 0.21 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.gamma.spi_frequency 100000 # SPI frequency
motor_driver_control.gamma.sense_resistor 100 # set the sense resistor usedSerial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to trueExtruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 2092 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 50 # mm/sextruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5! # Pin for extruder dir signal
extruder.hotend.en_pin nc # Pin for extruder enable signalextruder offset
extruder.hotend.x_offset 0 # x offset from origin in mm
extruder.hotend.y_offset 0 # y offset from origin in mm
extruder.hotend.z_offset 0 # z offset from origin in mmfirmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
extruder.hotend.retract_length 3 # retract length in mm
extruder.hotend.retract_feedrate 45 # retract feedrate in mm/sec
extruder.hotend.retract_recover_length 0 # additional length for recover
extruder.hotend.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend.retract_zlift_length 0 # zlift on retract in mm, 0 disables
extruder.hotend.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current 1.0 # Extruder stepper motor currentmotor_driver_control.delta.enable true # delta (E1) is a TMC26X
motor_driver_control.delta.designator A # D to set the settings
motor_driver_control.delta.chip TMC2660 # chip name
motor_driver_control.delta.current 1000 # current in milliamps
motor_driver_control.delta.max_current 3000 # max current in milliamps
motor_driver_control.delta.microsteps 32 # microsteps 256 max
#motor_driver_control.delta.decay_mode 1 # decay mode default
motor_driver_control.delta.alarm false # set to true means the error bits are checked
motor_driver_control.delta.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.delta.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.delta.spi_cs_pin 0.4 # SPI CS pin
#motor_driver_control.delta.spi_frequency 100000 # SPI frequency
motor_driver_control.delta.sense_resistor 100 # set the sense resistor used.Second extruder module configuration
extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 2092 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend2.max_speed 50 # mm/sextruder.hotend2.step_pin 2.8 # Pin for extruder step signal
extruder.hotend2.dir_pin 2.13 # Pin for extruder dir signal
extruder.hotend2.en_pin nc # Pin for extruder enable signalextruder.hotend2.x_offset 18 # x offset from origin in mm
extruder.hotend2.y_offset 0 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
epsilon_current 1.0 # Second extruder stepper motor currentmotor_driver_control.epsilon.enable true # epsilon (E2) is a TMC26X
motor_driver_control.epsilon.designator B # E to set the settings
motor_driver_control.epsilon.chip TMC2660 # chip name
motor_driver_control.epsilon.current 1000 # current in milliamps
motor_driver_control.epsilon.max_current 3000 # max current in milliamps
motor_driver_control.epsilon.microsteps 32 # microsteps 256 max
motor_driver_control.epsilon.alarm false # set to true means the error bits are checked
motor_driver_control.epsilon.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.epsilon.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.epsilon.spi_cs_pin 4.29 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.epsilon.spi_frequency 100000 # SPI frequency
motor_driver_control.epsilon.sense_resistor 100 # set the sense resistor usedLaser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is ignored if false.
#laser_module_pin 2.7 # this pin will be PWMed to control the laser
#laser_module_max_power 0.8 # this is the maximum duty cycle that will be applied to the laser
#laser_module_tickle_power 0.0 # this duty cycle will be used for travel moves to keep the laser active without actually burningswitch.psu.enable true # turn atx on/off
switch.psu.input_on_command M80 #
switch.psu.input_off_command M81 #
switch.psu.output_pin 1.19 # small mosfet (NB not inverted)
switch.psu.output_type digital # on/off only
#switch.psu.ignore_on_halt true # so the PSU does not turn off on a HALT condition (like limit trigger)
# However leave commented or set to false if you want the PSU to turn off for an over heat fault conditionHotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.4 # Pin that controls the heater
temperature_control.hotend.thermistor Semitec # see
#temperature_control.hotend.beta 4066 # or set the beta valuetemperature_control.hotend.set_m_code 104 #
temperature_control.hotend.designator T #
temperature_control.hotend.max_temp 300
temperature_control.hotend.runaway_heating_timeout 225 # max is 4088 seconds
#temperature_control.hotend.p_factor 39.8 #
#temperature_control.hotend.i_factor 2.908 #
#temperature_control.hotend.d_factor 136 ##temperature_control.hotend.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
Hotend2 temperature control configuration
temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend2.thermistor Semitec # see
##temperature_control.hotend2.beta 4066 # or set the beta value
temperature_control.hotend2.set_m_code 104 #
temperature_control.hotend2.set_and_wait_m_code 109 #
temperature_control.hotend2.designator T1 #
temperature_control.hotend2.max_temp 300
temperature_control.hotend2.runaway_heating_timeout 225
#temperature_control.hotend2.p_factor 39.8 # permanently set the PID values after an auto pid
#temperature_control.hotend2.i_factor 2.908 #
#temperature_control.hotend2.d_factor 136 ##temperature_control.hotend2.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable true #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.thermistor EPCOS100K # see
#temperature_control.bed.beta 4066 # or set the beta valuetemperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
temperature_control.bed.max_temp 125
#temperature_control.bed.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
#temperature_control.bed.p_factor 200.1 # permanently set the PID values after an auto pid
#temperature_control.bed.i_factor 6.990 #
#temperature_control.bed.d_factor 1432Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 0.26 #switch.misc.enable true #
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 1.22 #Switch module for servo control
switch.servo.enable true # Enable this module
switch.servo.input_on_command M280 # M280 S7.5 would be midway
switch.servo.input_off_command M281 # Same as M280 S0 0% duty cycle, effectively off
switch.servo.output_pin 1.23 # Must be a PWM capable pin
switch.servo.output_type hwpwm # H/W pwm output settable with S parameter in the input_on_comand
switch.servo.pwm_period_ms 20 # set period to 20ms (50Hz) default is 50Hzautomatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervalsfilament out detector
#filament_detector.enable true #
#filament_detector.encoder_pin 0.26 # must be interrupt enabled pin (0.26, 0.27, 0.28)
#filament_detector.seconds_per_check 2 # may need to be longer
#filament_detector.pulses_per_mm 1 .0 # will need to be tuned
#filament_detector.bulge_pin 0.27 # optional bulge detector switch and/or manual suspendSwitch module for spindle control
#switch.spindle.enable false #
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
corexy_homing true # set to true if homing on a hbit or corexy
alpha_min_endstop 1.24 # add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.27! #
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min -10 # this gets loaded after homing when home_to_min is set
alpha_max 400 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.25 #
#beta_max_endstop 1.28! #
beta_homing_direction home_to_min #
beta_min -53 #
beta_max 400 #
#gamma_min_endstop 1.26! #
#gamma_max_endstop 1.29! #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 500 #optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches#probe endstop
#probe_pin 1.29 # optional pin for probealpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 2 # "
alpha_slow_homing_rate_mm_s 10 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 2 # "alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 1 # "#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
optional Z probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 2 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 10 # how much above bed to start probeassociated with zprobe the leveling strategy to use
leveling-strategy.rectangular-grid.enable true # The strategy must be enabled in the config, as well as the zprobe module.
leveling-strategy.rectangular-grid.x_size 397 # size of bed in the X axis
leveling-strategy.rectangular-grid.y_size 397 # size of bed in the Y axis
leveling-strategy.rectangular-grid.size 7 # The size of the grid, for example, 7 causes a 7x7 grid with 49 points.
# Must be an odd number.
leveling-strategy.rectangular-grid.probe_offsets 9,20,0 # Optional probe offsets from the nozzle or tool head
leveling-strategy.rectangular-grid.save true # If the saved grid is to be loaded on boot then this must be set to true
leveling-strategy.rectangular-grid.initial_height 10 # will move to Z10 before the first probe
mm_per_line_segment 1 # necessary for cartesians using rectangular-grid#leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
#leveling-strategy.three-point-leveling.point1 100.0,0.0 # the first probe point (x,y) optional may be defined with M557
#leveling-strategy.three-point-leveling.point2 200.0,200.0 # the second probe point (x,y)
#leveling-strategy.three-point-leveling.point3 0.0,200.0 # the third probe point (x,y)
#leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
#leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
#leveling-strategy.three-point-leveling.save_plane false # set to true to allow the bed plane to be saved with M500 default is falsekill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 1.30 # kill button pin.Panel See
panel.enable true # set to true to enable the panel code
Example viki2 config for an azteeg miniV2 with IDC cable
panel.lcd viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.26!^ # encoder pin
panel.encoder_b_pin 3.25!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.a0_pin 2.6 # st7565 needs an a0
panel.contrast 0 # override contrast setting (default is 9)
panel.encoder_resolution 2 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.30^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.22!^ # back button recommended to use this on EXP1
panel.buzz_pin 1.31 # pin for buzzer on EXP2
panel.red_led_pin 1.19 # pin for red led on viki2 on EXP1
panel.blue_led_pin 1.20 # pin for blue led on viki2 on EXP1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.21 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.18!^ # sd detect signal (set to nc if no sdcard detect) 1.18
panel.menu_offset 1 # some panels will need 1 hereExample miniviki2 config
#panel.lcd mini_viki2 # set type of panel
#panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
#panel.spi_cs_pin 0.16 # set spi chip select
#panel.encoder_a_pin 3.25!^ # encoder pin
#panel.encoder_b_pin 3.26!^ # encoder pin
#panel.click_button_pin 2.11!^ # click button
#panel.a0_pin 2.6 # st7565 needs an a0
##panel.contrast 18 # override contrast setting (default is 18)
##panel.encoder_resolution 2 # override number of clicks to move 1 item (default is 2)
#panel.menu_offset 1 # here controls how sensitive the menu is. some panels will need 1panel.alpha_jog_feedrate 6000 # x jogging feedrate in mm/min
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/minpanel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.T1_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selectednetwork settings
network.enable true # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.plan9.enable true # enable the plan9 network filesystem
network.ip_address 192.168.42.40 # the IP address
network.ip_mask 255.255.0.0 # the ip mask
network.ip_gateway 192.168.42.1 # the gateway addressExample of a custom menu entry, which will show up in the Custom entry.
NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.name Power_on #
custom_menu.power_on.command M80 #custom_menu.power_off.enable true #
custom_menu.power_off.name Power_off #
custom_menu.power_off.command M81 #Azteeg specific settings do not change
currentcontrol_module_enable false #
digipot_max_current 2.4 # max current
digipot_factor 103.0 # factor for converting current to digipot value
#51.0 for SD8825, SD6128, BSD4989leds_disable true # disable using leds after config loaded
custom_menu.blt_probe_out.enable true
custom_menu.blt_probe_out.name BLT_Probe_Out
custom_menu.blt_probe_out.command M280_S3#custom_menu.blt_reset_larm.enable true
#custom_menu.blt_reset_larm.name BLT_Reset_larm
#custom_menu.blt_reset_larm.command M280_S10.6custom_menu.blt_probe_In.enable true
custom_menu.blt_probe_In.name BLT_Probe_In
custom_menu.blt_probe_In.command M280_S7custom_menu.blt_reset_alarm.enable true
custom_menu.blt_reset_alarm.name BLT_Reset_Alarm
custom_menu.blt_reset_alarm.command M280_S10.6custom_menu.blt_reset_alarm.enable true
custom_menu.blt_reset_alarm.name BLT_Test_Alarm
custom_menu.blt_reset_alarm.command M280_S8.4|G4_S15|M280_S10.6|M280_S7
#custom_menu.bt_pbandj.enable false
#custom_menu.bt_pbandj.name ProbeyDaBed
#custom_menu.bt_pbandj.command G0_X0
