Azteeg X5 mini V2 & Viki2
Hi. There is a red push button available on the Viki2 (below SD slot). I have wired it to the pin 1.22 of the azteeg board, but I’m not able to right set it in the config file.
I tried to use it as panel.button_pause_pin without success.
Any idea ?
Thank you.
In the Panel section of documentation it mentions a default config for Azteeg and Viki
Looks like
panel.red_led_pin 2.8 # pin for red led on viki2 on EXP1
Go to Panel section of Documentation if you need any more info.
Thank you Matt for your feedback.
What is the difference between the “panel.red_led_pin” and the “panel.button_pause_pin”. I’m not sure we are talking about the same button.
I already check the documentation below which mention both red_led_pin and button_pause_pin
# Example viki2 config for an azteeg miniV2 with IDC cable
panel.lcd                                    viki2             # set type of panel
panel.spi_channel                            0                 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin                             0.16              # set spi chip select
panel.encoder_a_pin                          3.25!^            # encoder pin
panel.encoder_b_pin                          3.26!^            # encoder pin
panel.click_button_pin                       2.11!^            # click button
panel.a0_pin                                 2.6               # st7565 needs an a0
#panel.contrast                              8                 # override contrast setting (default is 9)
#panel.encoder_resolution                    4                 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin                      1.22^             # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin                       1.22!^            # back button recommended to use this on EXP1
panel.buzz_pin                               0.25              # pin for buzzer on EXP2
panel.blue_led_pin                           4.29              # pin for blue led on viki2 on EXP1
panel.external_sd                            true              # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel                0                 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin                 1.23              # set spi chip select for the sdcard
panel.external_sd.sdcd_pin                   1.31!^            # sd detect signal (set to nc if no sdcard detect)
panel.menu_offset                            1                 # some panels will need 1 here
I’m not allowed to publish picture URL to show you the red button I’m talking about.
