Azteeg X5 mini v3 respondance errors
Hi Forum,
i recently upgraded my mini Delta Kossel with an Azteeg X5 as i wanted to test out the 32 Bit Processing. I wired everything up as shown in the wiring diagram and modified my config as needed. Somehow i then had issues with my endstop, but after i flashed my firmware yesterday those work just fine. Still i’m having a problem and don’t have a clue where the source of it lays.
When starting up my board everything fires up just fine my hotend cooling fan spins and the endstops work perfectly with M119. But there i encountered the first problem. Sometimes when i type the command the controller takes up to half a second to respond. Also when pressing the Home Button sometimes the controller takes a bit of time till it homes. Also when i perform a G1 command the motors spin a bit than stop again and then start moving again, stopping and going all the time.
If you need any information about my setup feel free to ask, I just can’t figure what’s the problem with the board.
Thanks for your answers in advance
What are you using to talk to the board ? ( interface, software, etc )
I’m using Pronterface but somehow the problem solved itself ;D
I really don’t know what made it work but after some calibration i now have no problems with the board anymore.
I just have one more question and that is how to use the network on the azteeg. I added the network enabling lines in the config but when i type @net in Pronterface it just responds with no network detected. Also thanks for always being around on Thomas Streams those really helped through the configuration process when i needed some distraction ;D.
