Azteeg x5 mini w/ Viki 2 LCD
Working on getting this set up now.
Everything seemed pretty straight-forward from the documentation except for one thing, the INT-USB jumper.
l previously used a v1.1 board w/ a ThinkPad running lubuntu to control it, but now will be using the LCD for the most part. This means that I should put the jumper on INT and the 12 (or 24) V power from the power supply will power the board? If I then wish to tweak some settings can I then plug the USB cable from a computer in or do I harder to power down and switch the jumper and restart with the computer as I previously did?
Got an answer on Reddit: /r/3Dprinting/comments/4jw6zk/azteeg_x5_mini_w_viki_2_lcd/d3a5di3
So yes, AIUI, leave jumper at INT, and connect / disconnect computer to communicate at need when the system is powered up.
Well, re-wired everything, and tested the USB and panel functionality —- also powered up w/ the 24V power supply (but w/ the wrong SD card) and all seemed okay. Will look things over once more tomorrow and then secure things in the enclosure and reconnect the fan.
