Azteeg x5 mini with tmc2100
hello guys,
im building a corexy printer and using the azteeg x5 mini v3 as the controllerboard and 42BYGHM809 0,9 degree motors.
and i would like to be the tmc2100 to be the stepper driver but i can’t get them to work properly. When the motors are not moving they twitch. you cant see them moving but you can feel it making tiny movements. Also when i try to move after a few movements they stop and the printer tells me to reset. I think this might be because the rev voltage on the stepper driver is wrong and they overheat.
On the github of the tmc2100 is has a note at the faq about settings the voltage on the stepper
Note: On some stepper motor drivers the maximum current (e.g. A4988) is set via Vref and on others the RMS current (e.g. TMC2100).
so the rms current of the motor is 1.7A so i have to put ref v on the stepper driver to 1.7 right?
I also left the cfg2 pin out on the stepper driver and put a jumper on m3 on the board to put it to 1/16th steps and under here is my configfile
?# Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate 6000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 6000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.1 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation
mm_per_line_segment 0 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
  1. Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 320 # Steps per mm for alpha stepper
beta_steps_per_mm 320 # Steps per mm for beta stepper
gamma_steps_per_mm 400 # Steps per mm for gamma stepper
  1. Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 3000 # Acceleration in mm/second/second.
z_acceleration 300 # Acceleration for Z only moves in mm/s^2, 0 disables it, disabled by default. DO NOT SET ON A DELTA
junction_deviation 0.01 # Similar to the old "max_jerk", in millimeters, see : link
# and link . Lower values mean being more careful, higher values means being faster and have more jerk
  1. Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
arm_solution corexy
  1. Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11 # Pin for alpha stepper direction
alpha_en_pin 0.10 # Pin for alpha enable pin
alpha_current 0.7 # X stepper motor current
x_axis_max_speed 30000 # mm/min
alpha_max_rate 30000.0 # mm/min actuator max speed
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction
beta_en_pin 0.19 # Pin for beta enable
beta_current 0.7 # Y stepper motor current
y_axis_max_speed 30000 # mm/min
beta_max_rate 30000.0 # mm/min actuator max speed
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 0.7 # Z stepper motor current
z_axis_max_speed 6000 # mm/min
gamma_max_rate 6000.0 # mm/min actuator max speed
  1. Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 250000 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
#leds_disable true # disable using leds after config loaded
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
## Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 417 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 10000 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 75 # mm/s
extruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5 # Pin for extruder dir signal
extruder.hotend.en_pin 0.4 # Pin for extruder enable signal
delta_current 0.55 # Extruder stepper motor current
  1. Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( "hotend" ) module at all. All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend.thermistor Semitec # see link
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.designator T #
temperature_control.hotend.max_temp 300 # Set maximum temperature - Will prevent heating above 300 by default
temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
  1. safety control is enabled by default and can be overidden here, the values show the defaults
#temperature_control.hotend.runaway_heating_timeout 900 # max is 2040 seconds, how long it can take to heat up
#temperature_control.hotend.runaway_cooling_timeout 0 # max is 2040 seconds, how long it can take to cool down if temp is set lower
temperature_control.hotend.runaway_range 15 # Max setting is 63°C
temperature_control.hotend.p_factor 100 #
temperature_control.hotend.i_factor 7 #
temperature_control.hotend.d_factor 181 #
temperature_control.bed.enable true #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.thermistor EPCOS100K # see link
#temperature_control.bed.beta 4066 # or set the beta value
temperature_control.bed.p_factor 220 #
temperature_control.bed.i_factor 11 #
temperature_control.bed.d_factor 500 #
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
  1. Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 1.25 #
switch.misc.enable true #
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 0.26 #
  1. automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
  2. useful to turn on a fan or water pump to cool the hotend
temperatureswitch.hotend.enable true #
temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
  1. filament out detector
filament_detector.enable false #
filament_detector.encoder_pin 0.26 # must be interrupt enabled pin (0.26, 0.27, 0.28)
filament_detector.seconds_per_check 2 # may need to be longer
filament_detector.pulses_per_mm 1 .0 # will need to be tuned
filament_detector.bulge_pin 0.27 # optional bulge detector switch and/or manual suspend
  1. Switch module for spindle control
switch.spindle.enable false #
  1. Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
corexy_homing true # set to true if homing on a hbot or corexy
alpha_min_endstop 1.24^ # add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.24^ #
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 200 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.26^ #
#beta_max_endstop 1.26^ #
beta_homing_direction home_to_min #
beta_min 0 #
beta_max 200 #
#gamma_min_endstop 1.28^ #
gamma_max_endstop 1.28^ #
gamma_homing_direction home_to_max #
gamma_min 0 #
gamma_max 260 #
alpha_max_travel 210 # max travel in mm for alpha/X axis when homing
beta_max_travel 210 # max travel in mm for beta/Y axis when homing
gamma_max_travel 270 # max travel in mm for gamma/Z axis when homing
  1. optional enable limit switches, actions will stop if any enabled limit switch is triggered
alpha_limit_enable false # set to true to enable X min and max limit switches
beta_limit_enable false # set to true to enable Y min and max limit switches
gamma_limit_enable false # set to true to enable Z min and max limit switches
#move_to_origin_after_home false # move XY to 0,0 after homing
#probe endstop
#probe_pin 1.29 # optional pin for probe
alpha_fast_homing_rate_mm_s 60 # feedrates in mm/second
beta_fast_homing_rate_mm_s 60 # "
gamma_fast_homing_rate_mm_s 40 # "
alpha_slow_homing_rate_mm_s 15 # "
beta_slow_homing_rate_mm_s 15 # "
gamma_slow_homing_rate_mm_s 2 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 2 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
  1. optional Z probe
zprobe.enable false # set to true to enable a zprobe
zprobe.probe_pin 1.29!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 5 # how much above bed to start probe
  1. associated with zprobe the leveling strategy to use
#leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
#leveling-strategy.three-point-leveling.point1 100.0,0.0 # the first probe point (x,y) optional may be defined with M557
#leveling-strategy.three-point-leveling.point2 200.0,200.0 # the second probe point (x,y)
#leveling-strategy.three-point-leveling.point3 0.0,200.0 # the third probe point (x,y)
#leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
#leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
#leveling-strategy.three-point-leveling.save_plane false # set to true to allow the bed plane to be saved with M500 default is false
  1. kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable false # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
  1. Panel See link
panel.enable true # set to true to enable the panel code
panel.lcd mini_viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.26!^ # encoder pin
panel.encoder_b_pin 3.25!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.a0_pin 2.6 # st7565 needs an a0
panel.contrast 4 # override contrast setting (default is 9) miniViki (4 or lower)
panel.encoder_resolution 1 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.30^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.30!^ # back button recommended to use this on EXP1
panel.buzz_pin 0.25 # pin for buzzer on EXP2
#panel.red_led_pin 2.8 # pin for red led on viki2 on EXP1
#panel.blue_led_pin 4.29 # pin for blue led on viki2 on EXP1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 1 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.23 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.31!^ # sd detect signal (set to nc if no sdcard detect)
panel.menu_offset 1 # some panels will need 1 here
panel.gamma_jog_feedrate 6000 # z jogging feedrate in mm/min
panel.hotend_temperature 210 # temp to set hotend when preheat is selected
panel.bed_temperature 50 # temp to set bed when preheat is selected
custom_menu.pause_print.enable true #
custom_menu.pause_print.name Pause_print #
custom_menu.pause_print.command M25|G91|G1_E-5_F600|G1_Z20_F6000|G90|G1_X0_Y0_F6000 #
custom_menu.resume_print.enable true #
custom_menu.resume_print.name Resume_print #
custom_menu.resume_print.command G91|G1_E6_F600|G4_S1|G1_Z-20_F6000|G90|M400|M24 #
custom_menu.load_filament.enable true #
custom_menu.load_filament.name Load_filament #
custom_menu.load_filament.command play_/sd/scripts/loadfilament.g
custom_menu.unload_filament.enable true #
custom_menu.unload_filament.name Unload_filament #
custom_menu.unload_filament.command play_/sd/scripts/unloadfilament.g
custom_menu.set_z_zero.enable true #
custom_menu.set_z_zero.name Set_Z_Zero #
custom_menu.set_z_zero.command M306_Z0|M500 #
custom_menu.save_config.enable true #
custom_menu.save_config.name Save_Config #
custom_menu.save_config.command M500 #
custom_menu.fan_on.enable true #
custom_menu.fan_on.name Fan_on #
custom_menu.fan_on.command M106_S255 #
custom_menu.fan_off.enable true #
custom_menu.fan_off.name Fan_off #
custom_menu.fan_off.command M106_S0 #
  1. network settings
network.enable false # enable the ethernet network services
network.webserver.enable false # enable the webserver
network.telnet.enable false # enable the telnet server
network.plan9.enable false # enable the plan9 network filesystem
network.ip_address auto # the IP address
#network.ip_mask 255.255.255.0 # the ip mask
#network.ip_gateway 192.168.3.1 # the gateway address
  1. Azteeg specific settings do not change
currentcontrol_module_enable true #
digipot_max_current 1 # max current
digipot_factor 113.5 # factor for converting current to digipot value
