Back again, so i had my printer working, and then my extruder/hotend kept jamming,
Back again, so i had my printer working, and then my extruder/hotend kept jamming, took it apart, realized my heatbreak had bent.
So i assumed it was just me fiddling with the settings and had gotten the hotend too close to the bed. i put a new hotend and nozzle in, do the card/paper leveling trick, hit home multiple times to double check its right…i hit print, it homes, and then my nozzle is jammed into the bed!!!
why would it throw my nozzle into the bed only during print??? but not home too???
THEN, i can’t get my soft endstops working right, they were working at one point, but then i swapped my x axis and this hotend thing happened and im not sure where it got messed up but nomatter what i do i can’t get them to work like they are supposed to. the only way i can get it to print is to put a high number on both the min and max, its almost as if it is adding them together??? if i drop the max below .25 it won’t move at all after homing, if i set it at .25 it will run into walls…and i did try positive and negatives but not all combinations of them. but i swear its as if all my settings are changing on me or the effects of said settings change.
at one point i did manage to get it to stop it somewhere along the bed , but when i went to increase the number to get it to travel further it wouldn’t work.
now back to this bed issue, that is what really is annoying me right now, the endstops i feel like maybe i can figuer those out with some more tinkering, but the bed problem simply does not make any sense at all. I home, its perfect level, i hit print nozzle into bed…i hit pause, hit home…perfect level again…what???
[Steppers]
microstepping_x = 6
microstepping_y = 6
microstepping_z = 6
microstepping_e = 6
microstepping_h = 6
current_x = 0.5
current_y = 0.5
current_z = 0.5
current_e = 0.5
current_h = 0.5
steps_pr_mm_x = 10.0
steps_pr_mm_y = 10.0
steps_pr_mm_z = 50.0
steps_pr_mm_e = 26.15
steps_pr_mm_h = 50.0
in_use_h = True
slave_z = H
direction_z = -1
direction_h = -1
[Endstops]
invert_X1 = False
invert_X2 = True
invert_Y1 = False
invert_Y2 = True
invert_Z1 = False
invert_Z2 = True
end_stop_Z1_stops = z_ccw, h_ccw
end_stop_X1_stops = x_ccw, y_ccw
end_stop_Y1_stops = x_ccw, y_cw
soft_end_stop_min_x = -0.2
soft_end_stop_min_y = -0.2
soft_end_stop_min_z = -0.2
soft_end_stop_max_x = 0.27
soft_end_stop_max_y = 0.27
soft_end_stop_max_z = 0.2
[Heaters]
sensor_E = SEMITEC-104GT-2
[Cold-ends]
connect-therm-E-fan-0 = True
add-fan-0-to-M106 = True
[Planner]
max_speed_x = 0.3
max_speed_y = 0.3
max_speed_z = 0.03
max_speed_e = 0.2
max_speed_h = 0.03
acceleration_x = 3.0
acceleration_y = 3.0
acceleration_z = 0.5
acceleration_e = 3.0
acceleration_h = 0.5
[Homing]
home_speed_x = 0.1
home_speed_y = 0.1
home_speed_z = 0.1
home_speed_e = 0.01
home_speed_h = 0.1
home_x = 0.22
home_y = 0.16
home_z= 0.003
[Geometry]
travel_x = -0.4
travel_y = -0.4
travel_z = 0.4
oh and during the print my bed started going up instead of down…quiet interesting since it was printing down yesterday…
Is your Z axis inverted?
I see yes. Make direction_z=1 and invert it in Octoprint. Next try to print.
that switched the controls in octoprint so down actually makes the bed go down. when i click print, the print starts, and the bed drops like 5x what i set it at, i click pause, hit ‘home’ and it goes to where i set it…stupid…so again why does ‘printing’ put it at a ‘different’ distance than ‘home’ button…
so then i resume print, and after the first layer, nozzle into bed…im hoping to fix this issue before i ruin my last heatbreak
Why you have home_z = 0.003? In your configuration there is no space before “=”. Please check this detail.
ill check that but i think i just remembered something that i was doing with my previous setup and i forgot to do it the next day and caused my problems.
When i upload a file, and slice it, it tells me to ‘select a slicing profile’, nowhere in the guides did i see anything about how to create one, so i just picked one to use, regardless all the profiles show the same ‘command’.
Under advanced is this command
G1 Z15.0 F{travel_speed} ; move the platform down 15mm
and i was deleting it yesterday, can someone tell me why this is in all the slicer profiles? because to me it seems very strange to drop the z 15mm…i guess in a delta it might make sense for some complex reason, but its in all the profiles.
heck it still doesn’t make sense to me, and i can’t even download a profile to edit one, so i can’t import my own, and it sure is annoying having to remove that line every time. unless its to make sure the nozzle doesn’t hit and its ‘supposed’ to go back up afterwords
anyways hopefully that ‘space’ fixes that i guess, on a side note, if u look at the line under the perusa profile it says that line moves it 15mm, but the command is actually for 5mm lol
"G1 Z5.0 F{travel_speed} "
be back in another 30mins-hour after i test these settings
so 4 hours later and im back at the config i posted with the -1 direction.
what appears to be happening, and im really tired so this could all be wrong, but if i leave the original ‘perusa advanced settings’ alone, it will home, lower the bed, then raise the bed, and somewhere in all of that i lose my bed height settings which jams my nozzle into the bed or puts it so close it can’t put out extrusion.
so what i have to do is disable those “z axis” options in ‘advanced gcode’, then “home” BEFORE i print…so i got it working, i think, but its some stupid hack job that will drive me crazy, and i lose the nice little feature of moving the bed out of the way when the x crosses over it.
so in other words when the z axis options on, it homes, lowers the bed, then parks itself on the endstop essentially which makes no sense.
i guess it would be fine if i had my endstops zero’d in perfect…but then that is hard, and would make all these settings pointless. i think there was one gcode that said send z to 0, maybe i just need to remove that, im too tired but ill try that i guess tomorrow…
i kind of wish they never included any slicer profiles, i had to do the stupid redeem code by hand, i would have saved 3 days of headaches if they forced me to write the slicer profile by hand
Edit: Nvm ive confirmed im mentally retarded
Also check the local.config file (on redeem settings page - you can edit that in the browser). Sometimes an M500 command likes to write something in there that you didn’t intend. Check that - it overwrites EVERYTHING else. Delete anything in there that might be giving you pains.
i deleted the homing commands and just leveled my bed to my endstop, and after fiddling around i realized a bolt was lose on the z axis, so every time i homed thats why i kept getting a different result :(…dam ghosts in the machine i swear. but yah i guess building a 3d printer is alot more frustrating than i had imagined. oh well, mid life printer build crisis over, for now
yah so how do i stop the redeem going blank in octoprint settings? they say the ‘first’ time you just have to upload a blank local.cfg, and then it will show up after that, however nearly every time i shut down, and then reboot its blank again, i am using the shutdown command in ocotprint before i power down. also i have a print estimate time of 28 minutes, but for some reason below that its saying 2 hours? do the octoprint mm/s override the redeem settings? i can’t quiet tell if changing the mm/s in octoprint is actually speeding it up or not
nvm its doing it again, it homes, goes to the home_z, but then it goes to the endstop for some reason that i can’t figuer out. what setting is telling it to go to the endstop? i checked and the printer is printing in the correct direction, im using corexy with no probe, using home_z to adjust nozzle distance from the bed, using perusa profile, and my printer profile with my bed size and z axis inverted, which i did because i also inverted it in redeem to try and fix this problem
i just need to know why the bed would move after homing and going to home_z, why does it go to the endstop, what setting is doing that?
fixed with offset_z
