Based on the polls I run here and FB, with almost 100 votes,
Based on the polls I run here and FB, with almost 100 votes, we can conclude that most use DXF and produce their files on a CAD solution. But if we consider that CDR, SVG, AI as a graphic design solution, then they are the most. Now the questions would be if they where given the option ( because they are obligated to use CDR) would the use/learn a CAD solutions?
Poll, results https://plus.google.com/+ArielYahni/posts/gUcihTHZXRz
I do all of my vector creating in CAD and import to Corel. There I may add raster images for engraving, or make minor adjustment changes. Once finished, I then save the final product as CDR. In the future, if I want to re-use the drawing, it is easy to open the CDR, and go from there.
If you don’t have a background in any other application, then I would suggest a serious look at Corel (the new X8 especially). Corel was designed and developed as a 2D design tool first & foremost.
I also use AI and there isn’t anything that can do Corel can’t. AI’s design roots came out of Photoshop so it’s orientation is a bit different with more of an image and bitmap handling & modification approach.
Inkscape is more of a 3D base orientation from its design and just the ticket for a CNC device (and yes I know lasers are CNC machines).
They all do 2D design well but unless you’re already a devotee of one of the others (or even tools like Rhino, 123Make, etc) Corel is probably all you need. The Home & Student version won’t work with the K40’s add-in to drive the laser. The Educational version if you qualify is okay. For LaserWeb any version is good.
Agree with you @Jim_Hatch ​. Also i would say it’s all about what you allready are comfortable with but most solution of the same genre will provide you the same options.
It’s SketchUp and Inkscape for me…
