I am trying to change from Pronterface to BCNC. From information I can find I have done following:
- I have downloaded the cnc firmware. Renamed and flashed. On Sd card it is FIRMWARE.CUR and file size is 345kB. So I’m assuming the Firmware change has been OK
- I have downloaded the current config file from Smoothie website link. I have added one line grbl_mode true I haven’t changed anything else on the config file.
- I have downloaded BCNC successfully. When I try to connect Smoothie is listed.
The problem is BCNC will not connect with Smoothieboard.I have tried different baud rates it makes no difference.
Has anybody got at any suggestions?
