BeagleBoard.org  collaborates with Arduino  on ,
@BeagleBoard.org collaborates with @Arduino on #ArduinoTRE , eliminating the need for a PC in your projects
OK, Wow! I like the idea of the USB Hub and full size HDMI connector. Will the PinMux map out the same as the BeagleBoard so existing BeagleBoard projects can migrate over if needed / wanted???
What are you going to call the expansion boards, SHAPES SHield/cAPES ???
Who has started making adapter boards for all the Capes and Shields that are out there?
