Beaglebone Black power supply question (from an IC noob):
I have an old power supply that’s labelled with output of 5V and 2.5A.
Will this work for a BBB?
I see in the BBB System Reference Manual where it says, “The board requires a regulated 5VDC +/-.25V supply at 1A. A higher current rating may be needed if capes are plugged into the expansion headers.”
A higher current rating on the DC supply is fine. In fact if you plan to use capes you will need more current. The board consumes the current it needs. Having excess available will not cause any issues.
It should be. Make sure the voltage is within spec. After you plug it in check the voltage. Sometimes supplies that large have a minimum current to maintain regulation and the board only tales about .5A.
you have problems when you exceed the Amperage output rating of the adapter. if you do not exceed the output rating of the adapter, it should work just fine.
The voltage output of the adapter must match the device you are going to power; do not plug a 20 Volt adapter into a 5 volt appliance.
if the old beaglebone white is anything to go by (mine has seen a lot of abuse), it will just shut down if more current than supplied is asked for, but not be damaged or anything.
If the power supply has a lot of current, more than a few amps, I would have a fuse. I would hate to have an accident and blow a bunch of traces on the circuit board.
Unless you do something to the board to cause a short like maybe pouring water or melted solder over it, this will not happen. The PMIC shuts down and limits the current.
