Been having a problem with the hot end jamming.
Been having a problem with the hot end jamming. It will print well for a few minutes and then the hot end will jam and then the extruder gear grinds/strips the filament. Here are the printing specs:
FT-5 printer
E3D Titan and V6 hot end
PLA at 210 degrees
Print speed 35mm/sec
Travel speed 135mm/sec
Retraction speed I’ve tried 10mm/sec to 35mm/sec
Retraction distance I’ve tried .8mm to 2mm
Hot end fan cools effectively
Hot end temp is spot on
Any suggestions are welcome. Thanks in advance!
