#LocalTestFile - Before 3D printing out the whole model, test print tricky part first to adjust the settings. It will save you time and material. Read more: Filament and 3D Printer Test Print - Local Test File Technique
Hah. I have had to test ears like that too!
@Matt_Harrington Yes, better to make sure it works!
Sometimes I just print stuff in parts and glue them together. Or I may modify them slightly to have parts that fit together so that it’s not just glue that holds them. Then you can often avoid issues like the stuff above. However, it never looks as clean as it does if you can print it as one whole thing.
@Kevin_Danger_Powers Good point. Especially with larger items cutting and glueing is probably the only option.
