Best way to pause and resume
Is there a good way to pause a print partway through and then re-start?
I’d prefer not to have to edit the gcode manually, but I guess I could do that. If that’s the best way to go, what would the commands be?
It depends exactly how you are running the gcode file.
If you are using a host like pronterface, you just use that to pause and resume.
If you are playing from Smoothie’s sd card, you generally will want to use suspend/resume
See http://smoothieware.org/stopping-smoothie
Cheers.
