Bizarre first cut problem with CNC
Hi, I’m having a bizarre problem with the very first cut. The gcode seems very simple, but this has repeated itself three times now. Here’s the Gcode, created using CamBam with a custom postprocessor. It seems like the G00 doesn’t go to the right place, maybe 5mm off in X. The effect is that the Z goes down, makes the (off by a few mm in X) cut in Y, then the rectangular area is cut out correctly. I’m uploading the code file using the web interface, and playing the file from there locally.
G61 should put the system in absolute stop mode. But it doesn’t seem to be in the list of supported gcodes. Could that be a problem?
( Made using CamBam for SmoothieBoard )
( Shredder 6/6/2016 3:55:06 PM )
( T1 : 3.175 )
( TOOL/MILL,1,0,20.0,0 )
(STOCK/BLOCK,200.0,200.0,18.0,40.0,10.0,18.0)
G21 G90
G00 Z3.0
( T1 : 3.175 )
T1 M6
( Profile1 )
G61 G17
M3 S1000
G00 X16.5875 Y11.5875
G00 Z1.0
G01 F100.0 Z-2.0
G01 F600.0 Y68.4125
G01 X123.4125
G01 Y11.5875
G01 X16.5875
G01 F100.0 Z-4.0
G01 F600.0 Y68.4125
G01 X123.4125
G01 Y11.5875
G01 X16.5875
… And so on.
Instead of a rectangular cut I’m getting:
With the cut on the left only being there for the very first cut
OK. Forget it. Belt slippage problem
G61 is not supported, however it will simply be ignored.
