@Brian_Cross now running with ChiliPeppr on an older laptop with Xubuntu and his Ox.
http://i831.photobucket.com/albums/zz240/briancrossatshawdotca/Ox%20CNC%20Build/DSC_0022.jpg
Yup, and it’s working fantastic! Thanks again John for developing this tool!
Brian
I assume you start SPJS from a console. Can you open another console and run ‘top’ and report CPU stats while CP is hard at work?
For example, I just ran the CP logo GCode on my Shapeoko2 run from my HPDV7t Quad i7 laptop (not ‘older’ by my definition).
I am actually surprised by the load (all GUI settings are CP defaults)
Tasks: 250 total, 2 running, 248 sleeping, 0 stopped, 0 zombie
%Cpu(s): 11.1 us, 1.3 sy, 0.0 ni, 87.6 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 8079588 total, 2930064 used, 5149524 free, 160484 buffers
KiB Swap: 8385532 total, 0 used, 8385532 free. 1397500 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
6269 carl 20 0 954488 218536 74408 R 71.10 2.705 2:09.64 chrome
6136 carl 20 0 670064 179764 110844 S 17.28 2.225 0:53.09 chrome
6096 carl 20 0 1409064 137712 90628 S 5.980 1.704 0:29.11 chrome
1056 root 20 0 439044 78348 60392 S 4.319 0.970 0:52.85 Xorg
1785 carl 20 0 2986060 81932 55100 S 3.654 1.014 0:38.56 kwin
6453 carl 20 0 192628 8508 5560 S 1.329 0.105 0:00.47 serial-port-jso
Sorry, sort of hard to read on this community GUI. Chrome eating a lot of cpu (71.10 + 17.28) %.
This is openSUSE 64bit/KDE
I believe you are correct Jarret, and I believe what were are seeing is 3 separate Chrome Threads (2 x 4 = 8 total threads available) so one thread is 71% consumed, I’ll guess the one running WebGL.
1 thread at 100% would be 12.5% of CPU, 87.5% * 12.5* = ~10.9% rough round numbers for total CPU.
I’ll give that a go next run. openSUSE has both GUI and CLI utilization monitors galore; ‘top’ is sort of the universal default tool.
It will be interesting to see how well a laptop/computer performs when the Thread utilization gets in the high 90%s; does it play catchup gracefully or crash? I have several ‘older’ candidates in the pile in the corner, will try them sometime.
I’ll check on mine tonight to see how it does. I did crank the rendering down to 10 fps but I’ll try it at 30 as well. 30 didn’t seem to bog the machine down at all but it’ll be interesting to measure.
I agree, 10fps vs 30fps stats will be very interesting.Post your CPU stats as well.
