BTW, I bet it would work on PLA if you used dichloromethane instead of
BTW, I bet it would work on PLA if you used dichloromethane instead of acetone.
Originally shared by Whosa whatsis
NEED to try this.
Dichlo, as I like to call it despite chemical guys laughing at me, dissolves Pla very quickly
@Brook_Drumm I go with “DCM”.
I use weld-on #4, a solvent glue with DCM as the active ingredient. It works nicely for gluing (making the surface tacky pretty much instantly), but I wouldn’t describe it as dissolving PLA “very quickly”. Do you use a higher-purity source?
We order pure stuff from a chemical house… Not available to consumers. We also heat it and stir in the pellets. We use it to make electrically conductive stuff. It dissolves into a suspension in 30 minutes or so.
Wonder how well this will work with conductive or metall filler filaments. Been thinking a bit about metal plating a porous model made of conductive filament. How solid will i be …
I’ve always wanted to print and plate a collection of old hood ornaments
