Build Smoothieware with Config.txt embedded
Hi All
How can I build the firmware including the “config.txt”?
So I am sure the customers are not messing with the board.
Can I then use the micro SD card for store the G.code files as the main SD-Card?
I am not using the RepRap panel anymore
Thanks
Regards
Just edit the “config.default” file in the source, compile, flash, and it’ll use that file instead of the SD card.
