Bukito gimbal printed at 30%.
These things are fun to play with! :slight_smile:
Great to to see the results of a Bukito appear online. Still waiting for mine…
This actually wasn’t printed on a Bukito; it was printed on a Prusa i3…
No problem spinning it at 30% ?
I ended up scaling the outermost ring to 102% and the innermost ring down to 98%, but yeah it worked fine once I did that.
I found them too have slightly too much slop at 60% scale. Also, how, are your inner surfaces? I found the outer surface was perfect but the ones on the inner rings had a few warts and blobs…
You probably need to adjust your retraction settings so it retracts at a smaller gap distance.
Hmm, it’s at 1mm at present. It could be just Kiss creating some stops in the gcode. I’ll have a go with Cura tonight.
