enhydra
(Kurt Meister)
CAM and Material Database: After having successfully milled a PCB, I’m trying to use the Material Database. But no look yet…
#1 I defined a preset.
#2 Then I created an operation.
#3 I hit the Magic Stick and selected the preset
#4 The Operation is still “Laser Cut”
See also a the video below: https://photos.app.goo.gl/jiFI50sg0HIwTWB62
What have I missed?
P_Martin
(P. Martín)
2
Please, where can I find this application?
@enhydra not sure why this is happening to you. I think and older version had this issue
enhydra
(Kurt Meister)
4
@P_Martin Hm… A bit strange your question. You’re in the middle of it.
enhydra
(Kurt Meister)
5
@Ariel_Yahni_UniKpty Is this the correct procedure?
@enhydra it looks good ok to me. Not sure how you added it. Also are you running the lastest build?
@enhydra found and fixed! Will compile ASAP
