CAM: Strange behaviour while generating the gcode for pocket milling
The DXF was drawn in Fusion 360 and then imported to SketchUp for combining the lines to polylines - please don’t ask why I did it this way. ;-). When I then generate the operation with these dxf paths, it takes less than 2 seconds (Ellapsed: 00:01.558).
But when I do the combining job in Inkscape, then it takes ages until it’s done (if ever). Also no better result when I draw the rectangle and the circle directly in Inkscape.
So what about the SketchUp toolchain? Unfortunately importing DXF is a pro feature and plugins which added this function seem to disappear.
Any hints?
Edit:
With the native Inkscape shapes it took: Ellapsed: 21:09.680
With the imported and combined shapes : Ellapsed: 11:05.045
@enhydra Try this open inkscape and select all and ungroup, the go to extension / modify path and choose a very tiny value for example 0.1 ( this should not change anything on the design but pay attention )
Save as SVG and load in inskcape
