Can a few people send me copies of their config file I am interested
Can a few people send me copies of their config file I am interested in comparing what people have their acceleration, junction deviation and other movement settings set to… I feel as if I have something configured improperly and losing out on the full potential of LW
Here’s mine https://drive.google.com/file/d/0ByNecjb0RD-TNVotQkloclFXQ3M/view?usp=drivesdk
Thank-you @David_Cook
@Scott_Marshall You may want to take a look at this also, to compare configs.
@Alex_Krause which pin did you connect your laser enable? I’m curious of something.
@Jon_Bruno ​ on the psu or the smoothie?
On the smoothie… there has been some discussion on the 0.26 connection for the enable side of the 2 wire setup.
turns out that on the MKS SBase board that the TH4- pin is directly connected to an ADC ground pin which causes the laser enable to always be active. only extinguished when PWM stops. this could be a potential safety issue, as well as not properly working the pin…
switching to 2.5 is a better option for the enable pin in the 2 wire hookup across the board.
@Jon_Bruno ​ Pin 2.4! Ran on the negative of the small mosfet… ran into the always on issue myself with ground applied to level shifter… I’m running single pin enable config
Gotcha so nevermind you are good to go!
