Can any one of you guys post a working smoothie config please? My board is here, updated to the latest firmware, glcd works, just waiting to be connected but now I struggle to get through all the config options and I’m afraid not to mess something up, speeds and current values trouble me the most, also all the endpoint config with xmin ymax.
Thank you!
@Mircea_Russu What board do you have?
Mks sbase v1.3
I can send you my config but you’ll have to make it work for you
That’s not a problem. Only difference might be the pin assignment. Thank you.
Your email please
executivul at yahoo dot com Thank you!
@Mircea_Russu Make sure you change the Alpha and Beta stepper max current to the correct value for your motors. if you leave it at 1.5A you could burn out your stock K40 LPSU I have read that the typical max output on the 24v rail is 1.0A
I used 0.5 on both and can’t see any degradation in quality as missed steps. Thank you!
One thing I saw when I first tested at 1.5 was that the X axis would randomly switch direction. This was probably caused by the fields being to strong between the poles.
Of course the crecendo was when the power supply gave up the ghost.
