Can anyone give me a run-down of the blur1d function, how it works and parameters? I’m testing it out, adding random blocks of colour onto my 150 led strip using fill_solid, then running
blur1d(leds, NUM_LEDS, 60);
…in a loop. It is causing the blocks of colour to fade away in the manner of fadetoblackby, and the blocks - sort of - fade out at the edges first.
Can I specify a particular range or blocks of leds instead of NUM_LEDS?
If I’m applying it to NUM_LEDS (all my leds) how does it know to fade out (for example) the edges of just a fill_solid block of 30 leds lit up in the middle of the strip?
Also what is the last parameter for and what is its range?
I though blur1d’s function was to fade out a block of lit leds towards the edges, which it is doing, but it also produces a shimmering flickering effect as blur1d is repeatedly run and the lit leds fade. Is that what it’s supposed to do?
void setup() {
// put your setup code here, to run once:
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
void loop() {
int pos = random16(10, NUM_LEDS - 10); // = a random number between 16 - 134. Keeps raindrop away from edge, otherwise sometimes sum = random number!
int prand = random(2, 6); // the distance a single block of colour will extend either side of the central seed value “pos”
int left_pos = pos - prand; // extends the colour block ‘prand’ leds to the left
int right_pos = pos + prand; // extends the colour block ‘prand’ leds to the right
int ledcol = random(0, 255); //100-165 sets the leds to HSV greens and blues
leds(left_pos,right_pos) = CHSV(ledcol,255,255);
FastLED.show();
for (int i = 0; i < 20; i++) { // alter the i < x value to speed up or slow down the action
fadeToBlackBy(leds, NUM_LEDS, 1); // fade all leds by a small amount every loop
blur1d(leds, NUM_LEDS, 150); // "blurs" the blocks of colour = fading it out to left and right. Not sure what the value at the end does yet.
FastLED.show();
//delay(30); // enable and change value to slow things down
The value at the end is blend amount, and the fade is intended. From the source code: 0 = no spread at all 64 = moderate spreading 172 = maximum smooth, even spreading
173…255 = wider spreading, but increasing flicker
Total light is NOT entirely conserved, so many repeated calls to ‘blur’ will also result in the light fading, eventually all the way to black; this is by design so that it can be used to (slowly) clear the LEDs to black.
Aha I see - blur1d is blurring lit leds, smearing them to either side beyond the area I’ve actually told to light. So e.g. if you code “light up 5 leds in the middle of the strip red then do blur1d” what you get is maybe 15 leds lit up: the 5 original ones brightly and 4 or 5 either side tailing off in increasing dimness. The amount of smearing is dependent on that last value.
Cool
Each call to blur only smears each led to the two leds each side regardless of the blend amount, that value instead represents how much of the color is blended to those neighbors. To get 5 each side you’d want to call it five times (or see the same effect after 5 loops/frames).
The leds in the middle would also gradually dim, think of it as also smearing the black inwards. So in that example you’d probably want to set the middle 5 leds to the original color before each blur. Finally the whole thing would eventually fade towards black if you didn’t do that, so it would all end up quite dim.
Yes I’m blurring in a loop that runs 20 times, so am seeing more smearing than just the two adjacent leds, plus the whole thing is fading to black very nicely. Also getting a cool flickering/shimmering effect when the blur1d value is high but I slow the loop with a short delay or 20-30 milliseconds - not sure why that’s happening though…
I’m probably being dumb but I can’t see any reference to blur1d at those links. Could you possibly supply screenshots or details as to exactly where they are?
Brilliant, got it. Thanks.
This is working great. I’m lighting 9 leds at a time in random colours and random places, then blurring in a loop that also has a delay command in it. By tweaking the number of blurs (currently 16) and the delay time (currently 100) you can get a really cool balance, so the strip isn’t ever fully lit but is dynamically busy, and the interfacing and blurring between the different blocks of colour as they age and overlap and fade is fascinating to watch - lots of flickering and shimmering and all sorts
For anyone interesting in my amateur efforts here’s the script.
void setup() {
void loop() {
int pos = random16(10, NUM_LEDS - 10); // = a random number between 16 - 134. Keeps ‘raindrops’ away from edge
int prand = 4; // the distance a single block of colour will extend either side of the central seed value “pos”
int ledcol = random(0, 255); //any colour
FastLED.show();
for (int i = 0; i < 16; i++) { // alter the i < x value to speed up or slow down the action
// get above <x no. set right along with the delay value and it balances between filling the strip and fading it, constantly in motion blending and blurring.
// <16 with 100 delay at the end works!
blur1d(leds, NUM_LEDS, 255);
/* "blurs" the blocks of colour = fading it out to left and right.
173..255 = wider spreading, but increasing flicker
NOTE: it spreads the lit block wider, smearing it into nearby unl
FastLED.show();
delay(100); // enable and change value to slow things down
