Can anyone send me the gcode if 1×1×1 cm cube ? Pls send me link where I can download it
The gcode is going to be specific to the printer, so unless someone with the same printer slices it for you the gcode wouldn’t work at all. You need to find an STL which you slice into your own gcode, or find someone with exactly the same printer to do that for you.
There are many different sizes and styles of test cubes on thingiverse, but this is a 1x1x1 cm solid cube - http://www.thingiverse.com/thing:991401
@Stephen_Baird OK sir I got that…thank you btw
You will have better results if you generate your own g-code. As Stephen mentions there are a lot of settings specific to a printer that will make it problematic to use another persons code.
Download a free slicer like Cura, set up to your printer specs, bed size, material, filament diameter, resolution, etc and load the object above from Thingiverse on to the build platform. Export it out and see what you get.
Okay I got that
