Can I bit bang the same code to two different apa strips in parallel?
Can I bit bang the same code to two different apa strips in parallel? Or do I need to have 4 open pins. I have enough pins left over, just wanna know if I can keep some free.
You can connect several strip to the same clock pin and data pin
I have 8 ws2811 strip connect to a single Arduino pin (ws2811 not using clock pin)
